Bersh Roman
30 points
Posted on - 12/05/2012
Where can I find free speaker drivers for Windows XP and how do I isolate the drivers according to the PC brand at hand to avoid confusion in installing or wastage of bundles by downloading inappropriate drivers?
anjaneai
Acquiring free speaker drivers for Windows XP and isolating according to brand
Hi Bersh,
You can locate the Device Manager from Computer Management utility, from there you can scan for any hardware change, it should enlist all your system drivers, including the audio/sound card driver. Most of the devices are plug-in and play, in case, your OS fails to recognize the hardware and is unable to install the driver, you can simply google you specific driver by the exact Model Number/Brand corresponding to your Operating System.
There are several drivers which are apt for a bunch of hardware devices and easily recognized by these devices as well.
I hope this helps.
Thanks,
Anjaneai
Hi Bersh Roman,
Click on Start button > Settings > Control Panel > System > select tab Hardware > click Device Manager button > right-click on your speaker device > Properties > select tab Driver > click on the Update Driver button.
Choose “Browse my computer for driver software”, if there is any driver on your computer, then select the path for searching.
Choose “Select automatically for update driver software”, if not.
There will be a list of drivers. You will choose one fit to your device, depend on your device’s manufacture, device’s modern… This will prevent you from downloading are appreciated driver to your PC.
Hope this helps
