Acrobat could not open attachment.
Hi guys,
My attachments in blogs get damaged. The error message given below, I get when trying to open or download an attachment.
Can anyone suggest me about this issue?
Thanks for help.
Acrobat could not open 'moodle_usually_study_quiz_tool.pdf' because it is either not a supported file type or because the file has been damaged (for example, it was sent as an email attachment and wasn't correctly decoded).
To create an Adobe PDF document, go to the source application. then print the document to Adobe PDF.
Answered By 0 points N/A #155590
Mainly Its the problem of your file. The file you want to open is damaged. It may caused by virus or others. The error message which is shown on the Acrobat screen showed about all answer. Make sure that in which way you brought this file to your PC. If you collect it by others computer, that PC may affected by virus. Or if you collect it from mail then you should know that all kinds of file does not support on emailing. Very often it damaged by something.
Other reason  the PDF file creator was not genuine or copywriter. You must use real adobe product from the direct adobe link. Also remember that you must use ZIP soft. Because when you will send a mail to others you need to zipped that file immediately. Now you can send the file as zipped file and your file is now fully secure.
