Acrobat Could Not Run The Web Browser Unknown Error 123
When Acrobat could not run the web browser, unknown error 123 appears in the system and can fix the problem.
Acrobat could not run the web browser unknown error 123 occur when a user clicks on the link in the acrobat pdf application. The error appears because of the plugins of acrobat that are not installed on the web browser or when the user doesn’t use the default browser to open the link. The solution to fix the issue is to download the plugins of the acrobat on the web browser and make sure that the plugin should be active on the browser.
The user can also try to open the link through a different browser in the system. After that, try to open the link by taking the above measures.
