Acrobat Distiller Cannot Create The Temporary Folder Error 183
Give a detailed analysis on acrobat distiller unable to create the temporary folder error 183. Mention the solution to fix the error.
The acrobat distiller unable to create the temporary folder error 183 when Acrobat is trying to create a file in the Windows temp directory in a file called Adobe Distiller. The issue occurs when the user performs the print operation to print the pdf file. The solution to fix the problem is to give permission to the user account for this folder, and the problem should go away. The \windows \temp has security restrictions on the ‘users’ – changing that ‘users’ to ‘full control’ has allowed me to print the file.
