Acrobat Distiller Unable To Create The Temporary Folder Error 3
Briefly explain the acrobat distiller unable to create the temporary folder error 3? Describe the cause of the error code and explain the solutions to troubleshoot this error message.
The acrobat distiller cannot create the temporary folder error 3 when Acrobat is trying to create a file in the Windows temp directory in a file called Adobe Distiller. The issue occurs when the user performs the print operation to print the pdf file. The problem arises due to permission issues as the user is not assigned to get all the permission for the folder. The methods to fix the error code are as follows:
Method 1: Give the permission manually.
Go to the folder of Acrobat distiller and right-click on it. Go to properties and permit users to full control.
Method 2: Download the fixing tool
Visit outerphos.jugem.jp webpage and search for acrobat distiller unable to create the temporary folder error three and download the file, then run the installer to fix the issue.
Notifications
