Acrobat does not recognize VBA tutorial PDF Microsoft Project
I just received a VBA tutorial PDF Microsoft project but Acrobat won't recognize the file.  I use Adobe Acrobat XI and I'm having a "file not recognized" error.  Is there any other way to read this PDF file?  I'm on Windows XP 64 bit SP2.  Thanks.
Answered By 5 points N/A #139606
Hi Donna,
To verify if the file is an adobe file: Right Click the File > Left Click Properties. Check the type of the file. It should say something like “Adobe” or “.pdf”. If the file type says so then you might have a damaged file. You can try opening it up from another text reader program like notepad or word and see if it works. Also you may want to try adding a “.pdf” extension and try opening the file again.
Hope this helps!
