Acrobat Entry Point Not Found When Using With MS Office 2016
Why Acrobat entry point not found error occurs at startup? Describe the solution to fix the error code?
When Acrobat launches, Acrobat entry point not found error occurs on Windows 7 SP1 computers with Office 2016 with the error message ‘The procedure entry point ucrtbase.terminate could not be located in the dynamic link library api-ms-win-crt-runtime-|1-1-0.dll.’ The problem occurs in the system because of the Office 2016 installation, as it does not always install the VS2015 runtime on Windows 7 computers.
If the user installs the VS2015 runtime manually, then the acrobat application will be opened without any error.
The steps to resolve the issue are to download and install Microsoft Visual C++ (x64) runtime.
To download the above-mentioned software program, visit Microsoft Download Center and download Microsoft Visual C++, then install the program by double-clicking on the file.
Notifications
