lesliewestt
Posted on - 08/21/2011
Details of the error follow …
Acrobat has detected that there are missing components that require repair. Select the optional components you would like to repair and click Continue. Deselect a component to completely remove it. Click Cancel to cancel the component repair process.
Adobe PDF Printer
Create Adobe PDF files from any application by printing to Adobe PDF Printer. This will reconfigure the Adobe PDF Printer.
Adobe PDFViewer Safari Plugin.
View, fill-in and collaborate on Adobe PDFs within Safari. Cancel Continue
Hey Leslie,
Your error box is actually a screen showing that you need to 'update' these two components otherwise your software could give a run time error.
The solution for you is to check both components and then press continue. You should be able to continue without error.
Cheers.
I think you have installed an incomplete copy of Acrobat on your computer.
If you just downloaded the installer from the internet, then you have got an incomplete version. Ensure that you did not download a manipulated software where software already extracted the setup files.
Go to Adobe website and download the Adobe Acrobat.
