Acrobat reader file to jpg for S2
How do I convert a PDF file to a JPEG file for easier viewing on a smart phone? I have an Acrobat X Pro on an XP system and I would like to convert Acrobat reader file to JPEG then put it in my Samsung S2.
Answered By 30 points N/A #151741
Hi there Mega Joe Gardner,
Converting PDF files to JPEG images is a great idea to make them more accessible and lighter for viewing on the Smartphones!
To convert the PDF file to the JPEG file you will need some third party software. You can easily find plenty of converters for download via a simple Google search. They are mostly freeware, all are really simple to use and will do the job in a minute with just a few clicks. I'd recommend you to go with 4Videosoft Free PDF to JPEG Converter.
PDF to JPEG converter
If you don't feel like downloading and installing the software, you can always visit some of the websites offering the conversion of the PDF to JPEG (I.e. https://pdf2jpg.net/ ).
