hmnaeem77
Posted on - 07/29/2011
I’m a hardware and software installation service provider. I have a problem in using adobe acrobat reader x pro. The problem is” when I double click on the icon of the acrobat reader x pro or wants to open any pdf document, acrobat opens, a splash screen appears and then closed without giving any error message”. I have scanned my system for viruses and reinstall acrobat x pro but the problem remains same.
Acrobat reader x pro close while just opening
After reading your problem, I tough I would share some views on this issue. The problem you are facing is the sudden closing of “adobe x pro”. Well I would say there is nothing to worry about it. Please uninstall it from your operating system and re-install it again, I think the problem will be solved. Now if the same problem remains, the software you are using might have got corrupted, so in that case please go to https://adobe-acrobat-x-pro-update.en.softonic.com/ and download the latest version if the software. Please check for customer’s views and the download it. After downloading please install it and this time I can say that the problem will be solved for sure. Please do reply if you have trouble following the instructions I have said. I will be very pleased to help you out again.
