Acrobat Supported or Damaged file Error
Hi Dear,
Hi i am trying to use Adobe Acrobat but i am receive given error please provide me its solution.
I want to try read document, but i can't read due to the given error.
Detail of Error:
Acrobat Could not open ‘MyFile.pdf’ because it is either not a supported file type or because he file has been damaged (for example, it was send as an email attachment and wasn’t correctly decoded).
To create an Adobe PDF document, go to the source application. Then print the document to Adobe PDF.
Ok
Answered By 0 points N/A #114120
Except the reason mentioned in the error message, there are many other reasons which causes the PDF files damaged. Eg Virus attack, malfunctioning of the software, sudden shut downing the system, and large size of PDF files. Large files are tending to damage due to internet speed, network traffic etc.
You can recover damaged or corrupted PDF files using Advanced PDF repair.
Please follow these steps and make sure that you close down all the other applications including acrobat reader before you are doing this
Start Advanced PDF Repair > select the damaged / corrupted file (Here you can give a file name you like as it appears in the default name > click ‘start Repair’ and it will repair the file.
Even you can preview the recovered PDF by clicking ‘Show Recovered Document’
Regards
Colin
