Help!
I have the trial version of Acronis, now that I have the full version I installed it. I was about to create a bootable recovery CD when this Message came. I already have installed the full version, why is it still thinking as the trial one?
Backup Wizard
Acronis True Image Home
This is a trial version of Acronis True Image Home.
The selected operations cannot be performed. You can
purchase the full version of the product at
https://www.acronis.com/en-us/personal/buy-backup/?utm_redirect=buy&tracking=&x-segment=corporate
Acronis: Backup Wizard; Trial version error. Please help!
Have you registered your Product to Acronis?
Try Registering your product and restart your computer.
If that fails to uninstall the trial version and restart your machine, Install the registered Acronis Home and try to run the program again.
Hi Christopher_tabigue,
Arconis accept that there is a bug in the previous products and it will be fixed in the updates when new build is available it will be fixed. The simple answer to your answer is that you can't upgrade from the trial version. Install a fully activated software from their website. I hope this helped you.
Peter Franklin
