Autoit error & Acronis error these are the errors that I didn’t find a solution for them. I didn’t find anything on the Internet about them and I am stuck with them. Does anyone have any idea about these ? Should I be worried about them ?
Thank you !
Line 41:
Run, %SystemRoot%\System32Wogon.scr/s
Error: Unable to run program. (Ensure that backslasheshave been used properly).
Acronis shows error on log on in windows xp
I think you have mistake during the cleaning process, that may have dangerous results like unbootable computer.
Now follow the steps below
You need a latest combofix version on your desktop.
Do not open any browser
Close or disable all antivirus and anti malware, so that they do not interfere in combofix running.
Combofix will ask you to install recovery console, allow it.
Double click on the "combofix.exe" and allow the permissions
When finished, it will produce a report for you.
Always run combofix in safe mode. And do not open any program during the scan. Than there will be no problem again.
