Acronis True image 2013 for restoring password
Can Acronis True image 2013 be used to restore password ?
Has anybody recently restored password with Acronis True Image 2013?
Sandeep
Sandeep
Hi Sandeep.
True Image 2013 by Acronis is very good protecting software. It protects your photos, documents and many other important programs. It is a powerful data backup system. It is an online backup service.
You can easily backup your passwords here, restore them.
You can restore all your passwords on drives by-Drive Cleanser and File Shredder.
Thank you.
Hi Martin,
Can you give more details? Can system as well applications be restored?
Sandeep
Backup software comes in different forms. There are ones that will help you create a backup of your system by copying all the data as what was configured in the program to another location on the hard drive or maybe in another or different and separate media. I think this is what they call file-based backup method.
There are also software that backs up the system by making an image of the entire hard drive and that image will then be your backup copy.
Acronis True Image 2013 supports Windows XP, Windows Vista 32-bit and 64-bit, Windows 7 32-bit and 64-bit, and Windows 8. This backup software costs $29.99 and if you wish to have it, you can get it from here.
I think this could also restore your password if ever you happen to forget your new password and your old and original password is still present and preserved in the backup copy you created.
