Hello Experts,
I need to know more about disaster recovery and system migration using Acronis True Image Enterprise Server 9.1 with Universal Restore, Please do the needful for providing more inputs in this regard.
Thanks,
Ashley Glick
Acronis Universal Restore is is a fix when your system's hardware fails. It is an absolute combined module that brings back the servers or workstations to another hardware or virtual machine, giving an extreme amenable disaster recovery and migration options. This module will let you ready to the most unexpected events without needing administrators to buy and uphold similar extra machines.
This process will start when the platform agent is used to make a movable image that separate the data from the old computer's main hardware. Acronis Universal Restore will start in the new hardware drivers so the image from the prior hardware platform will let your computer to be restored perfectly to another hardware platform, including the operating system, programs and data, and the entire preceding settings. The Recovery can be use to the current system, to a new system with distinct hardware or virtual machines instantly by doing the following steps:
1. Start your replacement system with Acronis Backup & Recovery 11.5 bootable media you just made and then choose the Recovery option from the menu.
2. Choose the image that you wish to restore.
3. Acronis Universal Restore will start the restore process, identifies the hardware and install the necessary drivers for Hardware Abstraction Layer (HAL).
4. The outcome will be a flawlessly working system aon a new hardware platform.
