Is Acronis true image home 2010 supported by Linux?
Could you explain it thoroughly, if the Acronis true image home 2010 supported by the computer hard disks of Linux file and Linux operating system and please elaborate further, the ways and methods on how to remove the space file name in the linux operating system. Looking forward for your useful information and explanation, thank you so much.
Answered By 5 points N/A #105469
 I can understand the confusion you may be experiencing with regards to this problem. You can read a support document here: https://kb.acronis.com/content/3555. What this means is that Acronis True Image can work with these file systems but only to a certain degree. Unlike NTFS and FAT file system which are fully compatible and can be fully manipulated by Acronis, Linux file systems are not fully supported. You can't do file-level operations unlike with the NTSF/FAT file system, this means you can't recover files from images by mounting it. Also you can't save images on Linux file systems, you'd have save them on either NTFS or FAT file systems.
Hope this helps,
Howard Taft
