Acronis true image wd edition – wont resize from 900mg to 2000mg
Acronis true image wd edition – won't resize from 900mg to 2000mg. Any help would be really appreciated. The error shows failed to move the selected data. Thanks in advance.
Error
Failed to move the selected date. Make sure that your
new hard drive is not smaller than your old one and
partitions do not contain errors. You can check for
The errors and correct them using a special utility.
OK
