Hello Experts,
Act of war 64 bits compatibility error. I downloaded act of war game and was exactly following the correct instruction given but still it crashed and never return to the download process. I don’t know what the main reason of this is. I hope you can give me some answer for this problem.
Thank you experts.
Hallo Davis,
Well, if you downloaded a 64 bit version of the Acts of War and then it refused when you tried to install it, then that is an error due to compatibility issues. In order to resolve it, you will need to check the system specifications of your computer and check whether it is a 32 bit or 64 bit, and then download the Acts of War version that is compatible to your system.
Nicke
