Activate Windows program without Activation Code
If I have no Activation Code, how can I activate the Windows program?
It stops all my working and I am unable to solve this.
Help me!
Help me!
I am sorry but it is quite normal if you have a pirated version of windows have not originally bought windows at the first place.
However there are few steps you can follow to make it work for you.
1st method
Install the windows again using any key from the internet. And Switch off the Automatic Updates. These are one of the main reasons that you keep updating and they detect that your windows is not genuine.
2nd method
Click start and open the Run. Type oobe/msoobe /a . This command will activate your windows.
3rd method
When the activation message comes select the option where it says yes activate windows over the internet.
After that you should say No, don't register with Microsoft.
They will say thank you and your windows will be activated
Normally, the trial version of Microsoft Windows XP is set to 30 days. After that period, the operating system will automatically stop working and will automatically bring you to its activation page. When this happens, there is no other way but to activate the operating system if you want to continue using it.
Activating the operating system means purchasing a license key from Microsoft. If you don’t have a product key for your Windows XP then you cannot activate the operating system. To purchase a new product key, visit Get a New Windows Product Key. Unfortunately, because Microsoft has ended support for Microsoft Windows XP, Microsoft has stop selling new product keys for Windows XP.
Microsoft ended the Windows XP support on April 8, 2014. But luckily, according to a website, Microsoft will still allow new activations of Windows XP even after the said date. But this is only for product keys that are still working. If your product key has already a problem maybe because it already reached its activation limit, it is not genuine, or the product key is no longer available, you can still activate it even without the genuine product key.
The secret to activate Windows XP without a genuine product key applies only to the Professional edition. To begin, in Windows XP, click Start, Run then type without quotes “%systemroot%system32oobemsoobe.exe /a” then hit Enter. You can also type “c:windowssystem32oobemsoobe.exe /a”. On the next screen, click “Activate on the phone” and then select “Change Product key”. See image.
On the next screen, enter the following combinations on the specified fields and then click Update: VHC8F-MRJFF-TV4V2-J7DWJ-B9D76. See image.
After that, select your country and then dial the free phone number for your country. See image.
While calling, a computer will request you to dial your installation ID number. Dial your installation ID number. After that, take note of the numerical combinations that the computer will give you. See image.
Enter the number combinations in the activation program then click Next. See image.
And you are done. You have successfully activated Microsoft Windows XP without using a genuine product key.
