Activating AutoCAD 2014 fails with a license error
Hi All,
I have been attempting to activate AutoCAD 2014 on my computer and the following error message comes up during installation. I tried installing a couple of times after disabling my antivirus software. But this did not help me in any way. Then I attempted remove this installer and downloaded and saved a fresh copy of the installation file and then tried again. Even then, installation fails without activating and reporting this same licensing error. I have administrative access on this windows 7 machine. What else could be causing this error? Is there a patch or work around to fix this issue? What should I do, does anyone here have any ideas? Thanking everyone sending forward their ideas in advance.
Image:
Error:
A license error has occurred. Contact your technical support representative for assistance
To help determine the nature of the problem, the error code is: 110
