Activating windows in a new hard disk
I would like to know how to reinstall and activate Windows Vista again in a new hard disk as the first hard disk was damaged.
Can Windows Vista be activated only one time or can it be activated in a new hard disk again, using back up and restore?
Best Answer by Seth Sepultura
Answered By 0 points N/A #120392
There are ways to activate your Windows after installing a new hard drive. This is by using Online activation and or by Phone (calling Microsoft).
By online activation:
  • Click Start Button, then look for Start Search;
  • On the Start Search box, type slow. exe4 then press enter;
  • You may need to select your Country;
  • Installation Wizard will guide you through, follow the instructions;
By Phone activation:
This is you, calling Microsoft Department to activate your Windows;
Activation by Volume License Keys 716- 871-2781;
You may also call 888-352-7140;
For International users: Microsoft Activation for existing users
These are the ways to activate your Windows.
Answered By 0 points N/A #120393
You may Install Windows Vista on your new hard disk (HDD) but you can't restore your backup files on your new Hard disk unless you have a backup on one of the following:
  • Flash Drive
  • CD/DVD disk
  • External Hard drive
Steps Installing Windows Vista – You may download the complete print screen of these here.
(Incomplete for other's solution).
