Activation Code for Kaspersky IS 2012 is Not Suitable
floyd norris 20 points N/APosted on - 02/09/2012
I purchased Kaspersky Internet Security 2012 with the activation code included in the package.
I installed it correctly but when trying to activate it, I always receive an error that says my “Activation code is not suitable for this application.”
I tried to contact Kaspersky Lab Technical Support but up to this time, I don’t receive any feedback yet.
What is wrong with my product key?
Activation of Kaspersky Internet Security 2012
Hi friend,
First find out that you bought that Kasperskykaspersky internet security 2012 from any recommended source.
Because there are many unauthorized source those provide a fake product key.
The only best way is to purchase Kaspersky Internet Security 2012 with the activation code form online from kasperskylab.com then you will not face that type of problem.
This way you also can find online help directly.
You are not receiving replies from Kaspersky lab that means you are trying fake product key.
To activate this product you can find many help on blogs. Some blogs contain Kaspersky Internet Security 2012 activation code or trick for bypass product key.
If you can find some of them it will be helpful to you.
That error happens because the activation code that was included in your package was the wrong activation code for your product. If you purchased Kaspersky Internet Security, the activation code included was probably for Kaspersky Antivirus, Kaspersky Total Security, or others. The full error reads “Activation code is not suitable for this application” and this happens after installing the application when you are about to activate the product.
With Kaspersky, activation codes are unique for every Kaspersky Lab product. Because of this, you cannot activate a Kaspersky Lab product using the activation code for another Kaspersky product. To fix the problem, check that the activation code you enter matches to the Kaspersky product you bought, Kaspersky Internet Security. In the activation window, you can find the name of the product to which the activation code corresponds.
Kaspersky activation window
In the line “Corresponding application” in the activation window, it indicates the Kaspersky product to which the activation code you entered corresponds to. Compare the name of the product indicated in the “Corresponding application” to the name in the upper left corner of the window. If the names are different, uninstall the product and install the product that matches to the activation code.
Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Kaspersky product among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, go to Kaspersky Downloads and download the product that corresponds to your activation code.
1....
