I am trying to install Kaspersky Internet Security 2012 on my Windows 7 PC. But an error is appearing after I entered the product key of the software. I am using Kaspersky on my own PC only but I have installed it for few times now. I am really puzzled because I purchased this software few months ago only. Is it expired and do I need another activation key? Please send some help. Thank you.
Activation of Kaspersky Internet Security 2012
Activation error
Number of activations using this activation code has been exceeded
Activation Error in Kaspersky 2012
As the error message says, you have exceeded the number of times that you can use that particular activation code for the kaspersky antivirus application. As it is for some applications, they are set to be used a certain number of times, or they can also be set to be used on a certain number of computers and therefore when you exceed that limit that has been set you will surely get such kind of an error.
Therefore as a workaround to your problem you will need to do the following:
You will need to obtain another activation code and use it.
Otherwise you will need to get another copy of kaspersky antivirus and install it.
-Thompson Locker
Hello Sheryl
This happens very often when you try to put in the key again and again. Due to this one of the registry files of your computer becomes familiar to the server and it does not allow you to download the antivirus again and again. But there is nothing to worry about. Just log on to Kaspersky website submit your inquiry regarding the problem.They will definitely report you back within twenty four hours.If this does not help then just uninstall your antivirus program and also your Windows operating system and reinstall both of them again.This would surely solve your problem.
thank youÂ
Gaurav3282
