Activation Failed.Error code -24 in program installation
Hello experts
I have just installed the program and also bought the Pro version. It works fine, but when I try to enter the activation code it will give the following error message:
I don’t know what this error means. In picture effect, I can use the picture.  Need your help. Thanks.
Best Answer by Perry Deborah
Answered By 0 points N/A #106042
Hi Liezl Gomez,
  What program did you installed? Error code 24 usually means that the action is caused the error. This error is lead to missing and wrongly linked information and needed some files for properly working of the application. Try to uninstall and reinstall it again and follow the instruction given. This kind of error also need to access the internet to activate the application.
Hope this will help,
Gothamn Pil
Answered By 0 points N/A #106043
Hello!
I have a suggestion to fix the driver error code 24. You can fix the problem just by clicking your mouse. You will be able to completely fix the driver error code 24. Generally, it occurs because of spyware attacks. It may be caused by the current running program. When this problem occurs, the software freezes or closes on its own. There may be another serious problem. It could be fixed easily. Restart your PC, download the software “Driver Error Repair Tool”.
After downloading, you can easily fix the driver error code 24.
