Activation Of Microsoft Office 2010 Setup Using The Product Key.
Hello experts,I was curious to know that how I can download the Microsoft office 2010 setup and activate it. Please guide me through the steps.
First, you need to download the Microsoft office 2010 setup from the official website of Microsoft.
After the downloading of the software, a dialog box will visible saying that the software is not activated yet.
Choose change product key, and it will prompt you to input the key.
After this install the software and do any change if you want or recommended.
Wait for few minutes after the installation of the software restarts your system.
Verify your key after the setting up which will lead you to the full version of Ms-Office 2010.
Downloading Microsoft Office 2010 is easy because you can get it from the Microsoft website but to do this, you need to have a valid product key first. To have a product key for Office 2010, you need to purchase it from Microsoft or any affiliated store that sells Microsoft Office 2010. If you have a product key, visit Download Earlier Versions of Office.
Here, you need to enter your product key to be able to download a copy of Microsoft Office 2010. Before installing or downloading Office 2010, make sure your computer meets the requirements. Microsoft Office 2010 supports Windows XP Service Pack 3 (32-bit only), Windows Vista Service Pack 1, Windows 7, and Windows 8.x both 32-bit and 64-bit.
If you managed to download and install it on your computer, the next thing to do is to activate it. Here, you need to be connected to the internet to activate the entire Microsoft Office suite. To activate, run any Office 2010 application. For example, run Office Word then click on the Office button then select “Word Options.”
On the next screen, click “Resources” on the left pane then click “Activate” on the right.
When you activate Microsoft Office, the Microsoft server checks the product key you used to install Office and verify it if it is valid and authentic. If the product key is not valid, the activation will fail with an error message.
Notifications
