Good Day TechyV users!
I have accidentally deleted my document. My question, is there an available active data recovery software for Windows and Mac? I really need it. Any help would be appreciated.
Libbys Snyder
Active data recovery software for Windows and Mac
Firstly, I would like you to advise to stop using the drive any further as chances of data recovery becomes less if deleted files are overwritten.
In my knowledge I can suggest you to opt Stellar Data Recovery software for both Mac & Windows. Don't buy it, first try the free preview feature available in the software which will scan your drive & let you know about the recovered files. But yes, to make actual recovery one must register and this is the case with all recovery tools.
here you can download the free exe/dmg for win & mac. https://www.stellarinfo.com/file-recovery-software.php
