Active Directory Domain Services Installation Confusion
The DNS name "<single label DNS domain name> proposed for this Active Directory domain consists of a single label, which is not recommended. DNS domain name should be unique and fully qualified, consisting of one or more labels separated by a period ("."), followed by a top level domain.
Example: corp.<domain>.com
If you click No, you can assign a fully qualified DNS name like the example. If you implement a single-label DNS domain name, you must configure all member computers and domain controllers as described in article 300684 in the Microsoft Knowledge Base (https://support.microsoft.com/en-us/help/300684/deployment-and-operation-of-active-directory-domains-that-are-configur) so they can register records and resolve queries until the domain is retired.
Do you really want to assign a single-label DNS domain name to this Active Directory domain?”
I am getting this error right now and I have no idea of which to click whether to select Yes or No.
Error:
The DNS name "SLD" proposed for this Active Directory domain consists of a single label, which is not recommended. DNS domain names should be unique and fully qualified, consisting of one or more labels separated by a period (","), followed by a top level domain.
Example: corp.SLD.com
If your click No, you can assign a fully qualified DNS name like the example. If you implement a single-label DNS domain name, you must configure all member computers abd domain controllers as described in article 300684 in the Microsoft Knowledge Base (https://support.microsoft.com/en-us/help/300684/deployment-and-operation-of-active-directory-domains-that-are-configur) so they can register records and resolve queries until the domain is retired.
Do you really want to assign a single-label DNS domain name to the Active Directory domain?
