Active directory how can i find all computers in Domain
Active directory ,how can i find all computers in Domain
I have a large OU structure in AD. I want a easy way to export all computers in all OU's into a file.
Thanks as always.
Gowri.
Thanks as always.
Gowri.
Hey there, Trick here.
Here's how you can view the entire users in a domain in Active Directory:
And that's it. Hope this helps.
In Active directory all users and computers are listed already and you can just make a copy form there and make a file for such computers if they are in a group and have different policies then you can check that groups and then copy them from groups and keep them in a file. Although if you want to see a new computer which is adding to your domain then you can just click find in active directory to locate that computer but this new one also require permission such as admen password to join domain. If in active directory you are as a admen then you must have access to all computers and you can see all activities on that computers.
I hope this will work fine.
Notifications
