Active Directory Management Gateway Service (ADMGS) Errors and McAfee Anti-Virus Software
Hello TechyV buddies!
I am having some problem with Active Directory Management Gateway Service (ADMGS) . am using Windows Server 2008 on this ADMGS. However, I have encountered a problem while trying to run “import-module active directory” in Powershell. The error message is this:
“The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework 3.0 SDK documentation and inspect the server trace logs.”
Have anyone encountered this kind of issue? I have tried to solve this problem but I can’t find a solution to this. Can anyone help me solve this problem? I will be very thankful to any help rendered. Thank you!
