gaffyjen
30 points
Posted on - 07/29/2011
What is the difference between Windows 2000 Active Directory and Windows 2003 Active Directory?
Is there any difference in 2000 Group Polices and 2003 Group Polices?
What is meant by ADS and ADS services in Windows 2003?
Thanks,
Active Directory: Questions very urgent………..
Windows 2003 Active Directory presented various brand new security offers, as well as advantage emphasizes for example the capability to rename a dominion controller and even a whole dominion see Microsoft's homepage for additional parts.
Windows Server 2003 additionally acquainted various updates with the default settings that might be influenced by Group Policy you are able to see a point by point record of every ready setting and which OS is needed to back it by downloading the Group Policy Settings Reference.
ADS stands for Automated Deployment Services, and is utilized to fast take off indistinguishably-designed servers in imposing-scale adventure domains. You are able to get more data from the ADS homepage.
Identified piece: Active Directory for Windows 2000 and 2003: What's the divergence?
The profits of AD over NT4 registry aids
Dynamic Directory checked a change in the way that Microsoft supervises registry aids, moving from the even and equitably prohibitive namespaces utilized by NT4 areas and moving to an exact progressive catalog structure. There's a test part from the Windows 2000 specialized reference good to go here that will give you an exceptional presentation into the major departures among the NT4 and Active Directory index aids.
Although Windows Active Directory 2000 and Windows Active Directory (AD) 2003 have a lot in common; this is due to the fact that they were built on the same directory service architecture, there are some new features that were introduced on Windows Active directory 2003. One of these is the Install from media (IFM) feature of Windows AD 2003.
With this new feature, you can run a System Back Up from an existing domain controller (DC) to promote a new DC from a remote location, instead of running a DCPROMO (which is the case for Windows AD 2000), which utilizes network connection usually WAN (Wide Area Network), and could take up a little bit longer depending on your connection speed, so it could save you both time and network resources. Â
Another added feature is the Linked Value Replication (LVR). This addresses the replication issue with Windows AD 2000, which is, the group membership list is treated as a single data blob, which could lead to the changes made by one administrator overridden by the other administrator’s. In LVR, the individual values of a multi-value attribute are replicated separately between AD, avoiding replication conflict.
Windows Server 2003 Automated Deployment Services(ADS) is script-based installation solutions that lets you deploy and manage new Server installations through a central Microsoft Management Console (MMC) snap-in or Windows Management Instrumentation (WMI) scripts.
ADS is comprised of three services: the Controller service, Network Boot Services (NBS), and Image Distribution service. These services handle the sequencing of jobs, PXE boot requests, and volume imaging. NBS includes the PXE service and is mainly responsible for the ADS Deployment Agent's boot capability. The Image Distribution service supports the downloading or uploading of images through the Deployment Agent.
I hope this helps.
