Active directory rights management error
Asked By 130 points N/A Posted on -
Hi All,
I have been searching all the internet to find a solution for this error.
Can anyone through some light on how i can fix this issue?
Active Directory Rights Management Services
Active Directory Rights Management Services could not complete the task because an error occurred. This error may be caused by variable conditions.
Click "Details" to view the error stack trace.
Exception message:
Index was out of range. Must be non-negative and less than the size of the collection. Parameters name: index
Exception type:
System. Web Services. Protocols. SoapException (Inner Exception: System.ArgumentOut
Exception stack trace:
Any smallest change suggestion will help
Regards
Answered By 0 points N/A #108454
Try repairing your Network Operating System. If you have created your RDISK or the repair disk before, you can use the RDISK to restore the original state of your Network Operating System or the Network server. The problem comes from the index; you can also try booting on network safe mode to fix some errors. Try also running CHKDSK to fix disk problems especially indexing of system files and applications. Also try using Administration account or any account that belongs to the group of Administrators this might solve your problem. If none of your administrators account able to do that, That’s the time you need to run the RDISK.
