Actual Cause For Sttray64 Exe Application Error
The Exe is error usually arise as a result of program installation. Stray is a software program. If it is running and getting installed and the computer gets switched off or during the installation of the Windows Operating System. Stray is a program launched by ’IDT’ and used by IDT. To stop the error permanently, you need to delete IDT but before doing that make sure you have backed up all your files into some other device.
Some of the most common errors which you can find in stray are;
“Sttray64.exe Application error,”
“Sttrat64.exe is not valid win 32 application,”
“Sttray64 exe failed,”
“Sttray64 exe is not running,”
“Faulting Application path:stray 64.exe”.
