Odessa
Posted on - 12/10/2011
Recently I installed Ad-aware total security. This is the first time that I am using this program. I gave my laptop to my friend for a couple of days. When I want to run or update Ad-Aware I got error messages. Now I am little bit confused and I am not shore what is wrong. OS Windows 7. How can I fix this problem?
Thank you
Oddesa
Application Error
Exception EAccessViolation in module Ad-Aware2007.exe at 00094CAA.
Access violation at address 00494CAA in module ‘Ad-Aware2007.exe’.
Read of address 00000018.
OK
Ad-Aware 2007 Access violation at address 00494CAA
Seems like the adware tool has been corrupt. Your friend might have accessed the system files by mistake and changed some important files that are required for the adware tool to work properly, and therefore I will suggest to workarounds for you to get the adware tool up and working again:
You will need to run system restore to undo any changes that your friend might have made that are causing the application to malfunction.
In case the registry entries for the application have been corrupt, you will need to run a registry error fix program to fix the errors, and I will recommend ccleaner for you.
In case the application has been corrupted completely and cannot be repaired, you will need to reinstall it to remove any bugs that it has.
Regards
Thompson Locker
