Ad Block Extension Shows Error
I needed to install Ad Block extension to block annoying adverts. So I go to Tool then Extensions then Get more extensions. When I click to install the extensions, an error occurs saying incompatible extension. Is there any other way to solve this error without changing my Firefox version?
Error message:
Incompatible Extension
Adblock 0.5.2.039 could not be installed because it is not compatible with this version of Firefox. (Adblock 0.52039 will only work with Firefox versions From 0,7+ to .10+)
OK
