Adapter Causing Problem in My Acer Aspire 1410 Laptop
Asked By 610 points N/A Posted on -
I have been using Acer Aspire 1410 model laptop for the last one year, which is a gift from my elder brother. Accidentally, the adapter has been damaged at least two weeks ago and I tried to replace it with same model of the adapter but was unable to find it in the local laptop repairing shops.
At last I bought an adapter, which belongs to HP notebook. I bought it on the recommendation of the technician. He told me that the power supply system would still be the same, though it is not the same model. But after using for two weeks, I am feeling that my PC is working slowly. What do you think about this problem?
Best Answer by clerk
Answered By 0 points N/A #111786
Dear Watson,
If you have read the nameplate data very carefully, then there might not be any problem with your adapter. This could be related to other performance issues. Firstly go through the internet, about your previous model adapter nameplate reading (i. e. current, voltage etc.). Then compare it with the new one.
If you find all the parameters to be the same, there is no chance to degrade your laptop's performance. You can remove/ uninstall some unwanted applications from your laptop or you may do a system restore, that might take your laptop to the previous state. If nothing helps, you can try for a new Windows installation. This will totally solve your problem.
Answered By 0 points N/A #195432
In case you have a look at nameplate facts meticulously, subsequently right now there is probably not any issue with your adapter. This might be associated with additional functionality troubles. Subsequently compares the item with the completely new just one. If you locate each of the variables to get exactly the same, there is absolutely no opportunity to break down one's laptop's functionality.
You'll be able to remove/ uninstall some undesirable apps from a mobile computer or even you could perform a program regain, that will acquire one mobile computer for the earlier point out. In case nothing at all odds, you can look at for the completely new Home windows setting up. It will absolutely resolve your condition.
Regards.
