Hey. I am Arthur and I am new here in TechyV. I just need some help with my laptop which is already a year older. My laptop is an HP one.
No recent change was made, but I noticed that it says that my adapter is not plugged. I checked the cabling and all and seems like all are in its proper places. The adapter’s light is also turned on.
Seeing the setup, it is just the way it is from the first time I have used it. The only difference is, it says that it is not plugged in, but all the while, it is already charging. Is there a way to keep away with it telling me that my adapter is not connected?
Adapter not connected message but laptop is charging
You can use software to check your battery status it shows the fully details for the battery as well as it also shows the temperature of different parts in a Laptop. This software is easy to install and is free available on the web. The name of the software is "Batterycare" it will help to solve your problem. Also see that when you plug the laptop a beep comes from the laptop if it is working then your battery is fully functional. Although Try to solve your problem with these suggestions:
First shutdown your laptop
See where the battery of your laptop is located
Remove the cover of battery or if it is just lock unlock it first any screw can be removed with a screw driver.
put out the battery of your laptop. And keep it out for one minute. Clean the contacts if you can.
then simply place back it to your laptop in such a way you remove it.
This will solve the problem you are facing.
Also see the wires of your adaptor rather they are damaged or have any kind of fault.
Ok that's it.
Paul info.
If your system is not working properly like in your case, the power adapter is not detected properly, try installing all the necessary drivers for your laptop. For HP users, go to HP Customer Support – Software and Driver Downloads. Here, select the “Laptop” category then enter your machine’s serial number on the next page. You can find it printed on the side or bottom of the machine.
Click “Submit” to search for your product. When your product is located, click it to go to the download page. Select your correct operating system then download and install all available drivers and software for your laptop. If the page shows a different operating system, click to change then select your correct operating system. See if this fixes the problem.
