ADCS on a computer which is running on a Windows 2008 server
For example, you are the system admin for your company. The company’s network consists of a single Active Directory domain. You install an Active Directory Certificate Services or an ADCS on a computer which is running on a Windows 2008 server. You have the AD CS set as an enterprise certification authority (CA). Now, you’d like to be an online responder who will provide certification revocation data to clients. You install the IIS and online responder service on a Windows 2008 server. Then, you test the responder. However, it did not function as expected. What should you do then to make sure the Online Responder works properly?
