markye
10 points
Posted on - 09/13/2011
Hello Experts, Today, I am attempting to launch Microsoft Dynamics GP 10.0 and I received this message regarding the add-in initialization error. I tried to delete the dll in the folder, and the error goes away. Any more suggestions?< />
Add-In Initialization Error
Microsoft.Dynamics.GP.BusinessIntelligence.DeployDataConnections.dll:
That assembly does not allow partially trusted callers.
Add-in Initialization error in MS Dynamics
Hello there,
Well you basically get this kind of an error message when a file gets damaged in Microsoft Dynamics. In order to sort this issue you will have to rename the dictionary file and then Import it. After you import it the table relationship which you created will be finally restored.
Therefore let me give you a step by step instruction how to do this as I came across the same situation last week and I got it sorted out here- https://support.microsoft.com/en-us/help/981996. Just follow the instruction given here and that's it you're done. Good Luck.
Thanks!!
