Add inNI-DAQmx MAX Configuration Support 9.4 Problem
I have an application installer package and I want to add inNI-DAQmx MAX Configuration Support 9.4. I am using LabView but it is a network install so I don't have the CDs which of course the installer is asking for! That went to the NI website and downloaded the NI-DAXmz 9.4 installer, I then unzipped it and tried to put it in the correct folder
Then I receive an error message and there is no inclination of how to fix it. Any idea how I would go about it?
The media you have provided is a different version of the requested media.
Media Requested: NI-DAQmx 9.4
MEDIA Provided: NI-DAQmx 9.4
Path: C:Documents and Settingsa255wzzDesktopNI-DAQ
Answered By 590495 points N/A #138455
If this is the first time it happened while creating the installer package, try restarting your computer then try it again. Make sure that the requested media in your installer is the same version as what you provided in the specified URL. If you are using a .ini file in your installer, do a thorough check on the contents of the file and make sure that the version of the media indicated is correct and if the main executable of the file is supplied with an option make sure that it is using the right syntax for the command to avoid generating any errors when the file is called.
You may also try checking your computer for possible virus infection that is possibly affecting the whole process. Update your antivirus then run a full system scan on your whole machine. Make sure your antivirus is up and running every time you connect your computer to the internet.
