Hi, I want to install or add a moveable jquery login form template on some of my blog posts. I only have information to add the usual html simple type of forms with drop-downs. How do I code to make the form moveable so it moves whenever someone decides to put the form on different parts of the page first? Thanks! Please share available templates
Add a moveable jQuery login form template
Greetings Matthew Scheider,
For a moment I thought that's impossible. But when I googled I found out that you can actually do it easy with jquery.
But it will depend on the source code of your page.
So I can't explain you how to do it and I can't give you a free template you can look.
I found a good guide how to do it though and I think that's the best solution you can get.
Droppable: jQuery UI – Create Targets for Draggable Elements
Hope this helped you,
