Shirley
10 points
Posted on - 07/20/2011
Hi all!
One Mozilla add-on file that was uploaded to the hosting that I use now is FireFTP. I find it difficult to skip upload existing files hosted. If many files have been uploaded, should I bother to click the skip button continuously? In FileZilla, there is an option to skip all existing files hosted. Are there no Mozilla add-ons that work similar to FileZilla?
Add on Mozilla for FTP
I am also use FireFTP.I face same difficulty too.
There are no add on Mozilla that it works similar to FileZilla like FireFTP
Though, if you want to look it up, there's a compilation of Chrome extensions in my References.
Chrome Add on
Shirley
10 points
To bad there is no add on Mozilla like FileZilla 🙁
Its ok Chrome extensions will do that with extension.
Thanks so much Amar_rong.
