max ross
Posted on - 11/06/2011
I want to put a restriction on accessing internet that is being used by my employees. What software is necessary for me to use? If possible, I want a simple and easy to use application but helpful enough for me to manage and control the internet usage. Thank you.
Add Restriction on Accessing Internet
Hello Max,
You can add restrictions on accessing your internet using Winbubble. It is very easy to use and it help prevent anyone to make new folders, shortcuts and file formats. Aside from restrictions WinBubble also help your computer to prevent or avoid viruses. Some other features are restrictions to control panel, changing wall papers, disable internet explorer and other bowsers and more. It will also enable you to log in securely and force to enter username before logging in to windows and web browser. For more information about WinBubble, please visit the link below:
https://winbubble.en.softonic.com/
I hope it might help. Good luck!
Zorian
