Add-in ‘Tabs Studio’ failed to load or caused an exception
Posted on - 02/24/2013
I am trying to run Tabs Studio v2.0.5 of Visual Studio 2010 (CLR v4) from a network. I am getting an error number 80131515:
The Add-in ‘Tabs Studio’ failed to load or caused an exception.
Would you like to remove this Add-in?
If you choose yes, the file it was loaded from, \localhostdocsVisual Studio 2010AddinsTabsStudio.Addln’, will be renamed,
Error Message: <Unknown error>
Error number: 80131515
