Add The Animated Gifs For PowerPoint
I want to create the presentation using PowerPoint gifs so want to know, what are the animated gifs for PowerPoint? How I insert the animated gifs in PowerPoint?
The animated gifs are created using multiple pictures that are the same as each other. The gifs are small in size so it is very popular.
Add animated gifs for PowerPoint:
Method 1:
1. Open the PowerPoint and click on the Insert tab.
2. Now click on the Pictures. Select the picture and click on the insert button.
3. Now click on the slideshow tab and then click on the play from the current slide to play the gif.
Method 2:
2. Now click on the Online Pictures.
3. Now search for gif.
4. Select the gif and click on the insert button.
5. Now click on the slideshow tab and then click on the play from the current slide to play the gif.
