Can anyone help me on how to add hyperlink to my PowerPoint presentation? I would want to have it to lessen slides and to make it brief. Hoping for your great response.
Here are the simplest steps to follow in adding hyperlinks on your PowerPoint presentation:
1) Open an existing PowerPoint presentation or start working on it as you normally do.
2) Select a text on the slide you want to have to have the link connected. You can do it by dragging the word or words using your mouse.
3) Click “Insert” on the toolbar and select “Hyperlink” or you can use the shortcut key “Ctrl+K”. Wait for the ”Insert Hyperlink box” to appear.
4) In the “Link To” section which is located on the left side, click on the “Existing File” or “Web Page” if you want to use existing documents or website. Navigate afterwards the file you like to link in the “Look In” box. Or type the address in the “Address” field. Click “OK” and then your link is added.
Your question is pretty easy one for solving quickly. I can give a better way to solve it. Please use below steps to do your work. It's a very simple duty.
Insert a hyperlink to the same presentation.
In normal view, select the test or the object that you want to use as a hyperlink.
On the Insert tab, in the Links group, click Hyperlink.
Under link to. Click Place in This document.
Do one the following:
Link to a custom show in the current presentation:
Under select a place in this document, click the show that you want to use as the hyperlink destination.
Select the show and return check box:
Link to a slide in the current presentation.
Under select a place in this document, click the slide that you want to use as hyperlink destination.
If you need to know more and more about the hyperlink's usage, please use the link I have given below:
1....
