Adding more color using Illustrator CS4 on Mac
I am using Illustrator CS4 on Mac. How can I increase the black Pantone color to 10%? I need to add more black color on one section of my file and I am preparing for more colors to add. Please help.
To modify or add color you can either deselect all objects and double click the gradient tool or click the gradient tool which is normally at of the tool panel this is done to change or modify a gradient. To add color you may double click a gradient stop then specify the new color in the panel that appears. You can also change the panel that appears by clicking on the color or swatches icon which is normally on the left side. Click outside of the panel to accept the selection. The other option is to drag the color out of the color or swatches icon then onto the gradient stop. Note that if you create a color on the gradient stop then deselect convert in the setup dialog box to print the gradient's individual spot color separations.
