Adding a New Hard Disk Drive To Dell Server
Hello!
At the office, we have 2 divisions and one of the divisions had purchased a backup server. I installed a backup software in each laptop/desktop  to synchronize with the server so that the software can automatically backup the server without help from the users. This is needed since most users are not exactly following the latest technology updates.
The other divisions were also permitted to backup the server but they need to purchase their own HDD and then the HDD will be added to the same server. The server is Dell PowerVault, if I'm not mistaken. My boss wants me to organize it, so the other divisions can start backing up their files to the server.Â
I have never used Dell PowerVault so I don't know where to start. My boss expects me to do some recommendations about what type of HDDÂ is needed and how big is the size and when it can be done. If it's just the usual desktop server, I know I need a SATA HDD with at least 500 GB space and format it the usual way. I heard from a friend of mine that deals with Dell PowerVault, Â that you don't need to shutdown the server, you only need to plug the new HDD in and just let it run.Â
I really need some help on how to do that. I'd really appreciate if it can be broken down into simple steps so I can follow it without much problem.
Looking forward for your suggestions.
John
