I would like to know more about Flash CS4. What is the use of adding a button in my project? How to utilize the use of button in Flash? What are the attributes available for Text tool? What is a Filter? What are the options or properties included in this? How can I watch my animation? How to execute it and view it real-time? Please give samples on how to export it from Flash to any USB device? Please provide me information what are the file types that I use to inject sound in Flash CS4?
Thank you!
Adding objects in Adobe Flash CS4 and proper way to use it
Hello Edith!
In Adobe Flash, adding buttons or any objects that can be used in run-time will give the design more interactive. Buttons also gives more options or instructions when to execute specific actions in the animation file. The text available in Flash are TLF Text and Classic Text. The attributes we can use to modify or arrange the texts are almost as the same as MS Word. The character family, size, color and align. Margins, adjusting the justifications, the coordination of text either from left to right. There are different Text filters we can use in Flash. This includes Drop Shadow, Blur, Glow, Bevel, Gradient Glow and Bevel, and Adjust Color at runtime using actionscripts.
Export Animation
1. Â Go to File Menu >> Export and Export Movie.
2. Â Set the width and height dimension and click Export.
You can also export Animation from your Library
1. Â Right-Click the video clip or file.
2. Â Select Properties from the Context Menu
3. Â In the video properties click Export.
