Adding two more RAM Memory
I would like to add two more RAM Memory Cards. But DDR 2 was already phased out in the market. What alternative version of Memory card can I use to make my computer work faster?Â
Hi Techdee,
If your computer specifications states that it has to use DDR2 memory, then it will only work well with that. I do not think that DDR2 is totally phased out of the market, it is only just that it is scarce in the market and therefore it can be hard to find sometimes. But you can find it in some computer shops, but if it that turns out to be hard, you can try other options like purchasing online on sites like eBay which I am sure you cannot miss to get one.
Hope this helps.
_____
Lee Hung.
Hi….
So you want to increases the speed of the computer. If you have DDR2 slot in the motherboard you cannot use DDR1 or DDR3 ram for it. So if you want to increases the speed the only thing that you can do with ram is install a high capacity ram.
You can’t even us a DDR2 ram in the DDR3 support motherboard. All DDR1, DDR2 and DDR3 are physically different to each others.
So if you want to speed up the PC you have to change the motherboard and buy DDR3 support motherboard and install a high capacity ram.
There is no alternative RAM s for your problem.
Thank you ….
