cperez
Posted on - 05/27/2017
Hi. I do not have any technical education and I have been using Microsoft Word 2013 only for saving documents. I have to make a report on the Indian Financial System where I want to insert the image of the national emblem on each page along with the text over it. How can I do it? Thanks in advance.
Adding Watermark In Microsoft Word 2013 On Each Page.
Hello. The thing which you are talking about is known as watermark. Watermark is one of the features of Microsoft Word 2013 which helps you to write text over image/text. You can even create your Watermark in Microsoft Word 2013. Also, you can fade the watermark if it appears too bright and disturbs your text.
Following are the steps to add the watermark to your document-
Step-1
Go to the Design tab.
Step-2
Go to the Page Background section present in the Design tab. Then click the Watermark button. A set of built-in watermarks will appear on the screen. Click on the desired one.
Step-3
Select the Custom Watermark option. Printed Watermark window appears.
Step-4
Select Picture Watermark. A screen will appear where you can select your picture.
Step-5
If you want a faded watermark select the Washout option. Click on OK button. The watermark will be displayed on the pages. You can also set it to a particular page.
